Octane Standalone Crop an OBJ for section view
azims
Is it possible to crop an OBJ to create a section view in Octane Standalone?
If this is currently not possible in standalone, is it something which could be implemented in 3.07? I am hoping 6 clipping planes would allow for a complete section box.
Are there any other free/ not too expensive program which can import multiple OBJ and crop them for a section view?
Phantom107
Technically you could build a shader to do it... using the comparison nodes you could cancel out the alpha outside of the box I think. But that will definately impact performance plus it would have to plug into every material
azims
Is it possible to share a sample of such a shader?
azims
Bepeg,
Please explain how to go about this using Octane standalone.
Hi azims,
the trick is to untick the Camera visibility option in the object layer, so it will be catted by the geometry with the BooleanAir material assigned.
Here is a similar scene in .orbx format:
BooleanAirTestB.orbx
(1.97 MiB) Downloaded 239 times
ciao beppe
Hi azims,
I have just figure out to have not saved the .orbx before posting, sorry.
The following file should be more clean:
BooleanAirTestB2.orbx
(1.97 MiB) Downloaded 234 times
ciao beppe
azims
Thanks Bepeg,
As always you are the best.
