3ds max crashes when convert all is pressed
C. RAM Capacity (i.e. 6 GB)
Hi seems like 2015 max crashes when we are trying to convert the materials of the file attached thank you
- dumpster_max.rar
- (33.35 MiB) Downloaded 336 times
- paride4331
Hi coilbook,
Your issue is caused by missing mental ray legacy assets.
Remove them before converting your scene.
I also get crashes with convertion of models from time to time. Mostly releated to VRay composite materials as it seems. I have to untick the baking feature of unsupported materials to mak it work and re-built all materials manually.
Not best way but I understand an converter can't consider all kind of material combinations.
PURE3D Visualisierungen
- paride4331
Hi mbetke,
Do your crashes happen if .psd textures are in vray composite or other slots?
Did you notice this?
I didnt noticed or investigated. I will check next time the issue happend and report back.
