Hello guys,
since i am new to octane, i find myself in a tricky situation, where i need to render a bottle of gin.
With the standard Cinema4D physical renderer, the refraction in my bottle (and on the edge) looks much more realistic than my rendering on Octane.
I attached three images to this post. 1. is the original Cinema4D Physical Render. (Water index 1,33)
2. is the Octane render with a standard glass material from the Live DB (Index:1,65) and a water material at Index: 1,01.
3. is the Octane render with the same glass material (Index: 1,65) and the water material at Index 1,3.
4. a real picture showing the desired refraction.
Can you please look at them and tell me, what i did wrong?
The bottle itself is constructed with a lathe-object with the liquid being another lathe object intersecting with the bottle.
Is this modelling technique wrong?
Thanks in advance for your help and time!
Greets,
Felix
Glass refraction with bottle+water
difficult to say with your screenshot, there is not too much to reflect/refract right now compared with your reference, but in OctaneRender, you need that the liquid is slightly overlapping the glass, to have the correct effect.
Or modelling in a different way, like explaned in the picture below: ciao beppe
Hi beppe,bepeg4d wrote:Hi,
thanks for your help.
I am looking for the refraction especially on the back label refracting to the bottle sides. I modelled it with a small overlap.. so you think i should model the liquid completely inside the glass?
Thank you!
Hi, FLXmedia
If you deserve "real life" then all specular materials must have dispersion.
-- Glass settings:
reflection - 0.930
transmission - 1.000 (greyscale color)
ior - 1.509* (it's ior dispersed and the original ior is 1.53)
dispersion coefficient - 0.006*
rest default
-- Water at +/- 18 ºC settings:
reflection - 0.930
transmission - 0.998 (greyscale color)
ior - 1.323* (ior dispersed and original ior 1.333)
dispersion coefficient - 0.003*
rest default
* - see 2 formulas (convert from "abbe number" to "dispersion cofficient (= B)"; calculate from original refractive index (ior) to
ior dispersed) ---> viewtopic.php?f=25&t=61949#p316752 (look my message on Jun 24, 2017 11:37 am UTC)
--> I'm recommended you use PMC kernel for almost real life, if your videocard is very fast (eg: GTX 780, 980, 980Ti...).
-- Glass settings:
reflection - 0.930
rest default
reflection - 0.930
rest default
NOTE: I'm sorry for bad english due to mute
i7-12700KF
2x16GB RAM@DDR4-3600
MSI PRO Z690-A DDR4
Zotac GF RTX 4090 <3
SSDs OCZ RD400 0.5TB and Crucial 2TB SATA3
HDD 1TB SATA2
LG BD-RE BH16NS40
PSU 1kW
NEW ViewSonic XG2431 24"
i7-12700KF
MSI PRO Z690-A DDR4
HDD 1TB SATA2
LG BD-RE BH16NS40
PSU 1kW
LAST EDIT: water only (look my previous message) or
-- Water with 45% alcohol at 20 ºC settings:
reflection - 0.930
transmission - 0.982 (greyscale color)
ior - 1.350 (ior dispersed and original ior 1.360)
rest default
reflection - 0.930
rest default
i7-12700KF
MSI PRO Z690-A DDR4
HDD 1TB SATA2
LG BD-RE BH16NS40
PSU 1kW
i7-12700KF
MSI PRO Z690-A DDR4
HDD 1TB SATA2
LG BD-RE BH16NS40
PSU 1kW
Wow, thanks for your help man! I'm using the PMC kernel, since we are working with a 980ti.nuno1980 wrote:Hi, FLXmedia
-- Glass settings:
reflection - 0.930
rest default
reflection - 0.930
rest default
But, have you done something similar before? How do i have to model? Slight overlap in glass/liquid or small gap between that?
Thank you very much for your help!!
