hi guys,
i'm trying different glass materials and have the same issue with all of them, material its ok but depending on the viewing angle (when close to 90°) the glass turns to black with strange effects ( like gasoline on a ground) my mesh is a low poly not flat. i would like to get rid of that effect. any idea?
s.
problem with glass material
Hi djiin,
it's always a good idea to post some screenshots, anyway, I'm guessing, probably you have to increase the Specular depth in the kernel settings
ciao beppe
ciao beppe
thank you beppe,
yeah i've tried that, i've tried to 32, it does something but not removes all that strange black effect, weird.
also sorry i can't post any screenshots with projects i'm working on (confidentiality..) but i'm gonna try to mimic that on another mesh to post.
thanks
thanks
If your specular material is complex (such as diamond, 3D star...) or the number of specular materials is 2 or more then you should increase to 100 specular depthes.djiin wrote:thank you beppe,
thanks
EDIT: See - Very high spec depthes for remove blacks
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3
NEW ACER Predator XB273U F5 27"
Caustics at PT
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3
- octanegraff
Not really a proper fix. However i have found with any really shiny materials...that if the glass is against something, it will turn black. try to put the other objects around it at least 0.01 way from it.
