Problem with Stencil Conversion
LFedit
When I bring in a JPEG, and I have to use it as an Opacity map, or Stencil in modo terms, it wont convert on the fly. Is there a reason for this? Am I using the wrong image format or something?
So what I have to do is convert it to an octane override, then it puts the correct map in the opacity slot, but its an alpha image, then it doesn't work. If I make a RGB image, then just reapply the exact same pins, it works.
Am I doing something wrong? Would be great to be done with Octane overrides!
Almost forgot, Modo 902 sp3 OctaneRender 3.06 TEST 4 (3060003)
Win 10, Threadripper Pro, Dual 3090s
Can you provide a screenshot of the shader tree and the stencil image settings pls?
LFedit
sure. Here you go. I even showed how I converted it to an octane override and it still didn't work.
Also attached a shot of how the rgb image does work then.
Can you send me the scene and image pls?
LFedit
You bet. Here you go.
OpacityPorblem.zip
(280.87 KiB) Downloaded 380 times
Your stencil is a JPG - which the Octane plugin assumes does not have an Alpha channel. But you have Alpha Channel = Use for that image. So change Alpha Channel to Ignore, and it works.
LFedit
ahhhhh...
Thank you! Saves me time!
Kilian
Thanks. I had the same problem some years later.
Return to “Foundry Modo”
