Long render time + lot of noise
Fabrice
Hi
I'm rendering an landscape animation but my rendertime are very long (more than 30 min/frame) and the result is very noisy.
Rendertimes are very important (more than 30mn!!!) and still very noisy
but the scene is quit simple :
- a ground (no displacement)
- a few bitmap sprites particle for the trees
- HDRI (512x256 pixel) environnement for the lighting
and that's all.
Any advice about how to decrease render-time and get rid of the noise?
Tahnks
Octane 3.03.4 - 4.21
Max 2014
Win7 pro
RAM 24 Mo
GTX 980ti
GTX 780
Octane 3.04.5 + 3DS Max 2014 plugin (GTX 980 Ti + GTX 780)
mbetke
Using alphas for vegetation is really compute intesive. You will get faster results using "real" instanced geometry with moveable proxies.
PURE3D Visualisierungen
Fabrice
I agree.
But if I remove the particle trees, rendertime is still 12min wich is quite long for a plane and 10 lathe objects on it.
(and still grainy)
promity
If you use Path tracing or PMC render kernel - set GI clamp to 2 - it help to reduce a lot of render time.
AMD Threadripper 1950X/64gb ram/RTX 3080 Ti + RTX 2070/Samsung SSD 870 EVO 500 gb/
Lightwave 3d
mbetke
maybe share your settings here so we can take a look
paride4331
Hi Fabrice,
You probably are not using imp. Sampling or you modified the evironement mapping transformation and this generates noise issue.
viewtopic.php?f=80&t=60992&p=312417#p312377
Fabrice
Here it is.
promity
Ok, go to Path Tracing tab -> GI and change '1000000' to '2'. After that go to Kernel settings -> Max samples and change it from 16000 to 500-1000.
Lightwave 3d
Fabrice
Thanks Promity!
but with GI clamp set to 2 instead of 1000000 :
- rendertime is extremely shorten (cool)
- BUT no more light seems to be entering the scene. There is allmost no more bright zone on the objects. I'll try some higher values...
