export 3dsmax to standalone. Problem camera and shaders
finkaboutit
Hello,
I have some trouble with the 3dsmax to standalone workflow.
First i see the 3dsmax renders are less sharp than octane standalone render. On the same scene. Weird. [EDIT: It was due to camera settings changes between max and standalone]
So i decide to export my scene to standalone, for better results.
My first problem i encountered is about the camera.
When importing to standalone, the camera lose parameters pins. I can't set up my dof, fov or anything else.
The second problem is about shaders.
The names of my nodes disappear. I have a lot of nodes named "glossy material".. How i can do to refine my shaders ? impossible to retrieve all my shaders. I have hundreds of meshes.
A second problem appears about shaders, my animations disappear too. i used a float texture into 3dsmax to set the amount of the "mix material".
I try a lot of different nodes, but none of them are keeping animations.
How can i do to keep my scene like i have into 3dsmax.
A last question about importing from max to standalone.
How can i set up the frame range of an "abc" ?
I need to synchronize differents "abc" and all of them are imported at 0 frame.
I don't understand the 3dsmax to standalone workflow, we did the same from Cinema 4D and it works quite fine, how is that possible ?
Thanks a lot.
G.
paride4331
Hi finkaboutit,
at this time 3dsMax exports to SA with the camera inside .abc and no way to have settings such as DOF, fov etc.
if you want a fully editable camera, you have to create a new camera in SA.
A second problem appears about shaders, my animations disappear too. i used a float texture into 3dsmax to set the amount of the "mix material...."
about this issue, I will send it to the developers.
attached screenshot
finkaboutit
Hi Paride,
And thank you again about your answer ;).
I understand that the 3dsmax to standalone workflow is not really yet fully professionnally implemented and effective. I hope it will be soon.
About abc sync, i meant sync into standalone. I already exported my animations from max.
I will precise you the situation.
first, i export my car animation of my full timeline (all my sequence, it contains numbers of different takes. // frames from 0 to 600)
Then, i export my cameras animations ( only frames from 100 to 160 for example)
I import car animation into standalone, the frame range is beginning to frame 0 (everything is normal), but the cameras are also imported to the frame 0 and not from frame 100 to 160.
How can i resync abc containing my camera, please ?
Do i need to export camera from 0 to 160 to synchronize it or is there any other issue to time offset them ? (saddly, this solution is not good in every case and force me to export hundreds of unusefull frames of hundreds of meshes)
Thanks again ;).
G.
paride4331
Hi finkaboutit,
unfortunately it is not possible to export .abc from 100 to 160 because there is not a parameter "start from..." in .abc file.
the workaround is to export your animated camera from frame 0 to 600 and then render it from 100 to 160.
suvakas
Just to add something here.. Strangely, on my system standalone renders almost twice as fast as Max plugin.
I always render my animations in standalone. Does anyone know the reason?
Suv
finkaboutit
Thanks Paride.
It was i thought. I'm a little bit disappointed about that.
For me, the 3dsmax plugin version is not really complete. There is too much things are impossible to do.
And there is a lot of bugs.
c4d version is working well, but 3dsmax version is not fully professionnal. It's a "for some case" renderer.
I hope they will improve this version soon.
For now, i think it's expansive compared to fully functional c4d plugin version.
I'm losing too much time to looking for issues to troubles due to bugs or incompatibility with max.
Thanks again, i will waiting for a better upgrade.
g.
finkaboutit
suvakas wrote:Just to add something here.. Strangely, on my system standalone renders almost twice as fast as Max plugin.
Suv
Hello Suv,
have you the same settings in max and standalone ?
I really would render my scene twice as fast too ;)
Can you tell me if you have any troubles with some features ?
Have you the same problems like me ? (no texture node animation export, can't control parameters into cameras, camera settings not similar, etc..)
Thanks ;).
G.
paride4331
Hi suvakas,
Are you talking about the evaluation phase, or total samples calculation render time?
Return to “Autodesk 3Ds Max”
