macOS Sierra
NVIDIA GeForce GTX 775M 2048MB
16GB
CUDA Driver Version 8.0.63
OctaneRender 3.05.3 (Stand alone)
OctaneRender for C4D version: 3.05.3 R1
C4D R16.050 (Build RB131856)
I keep receiving an error message suggesting that " The plugin liboctane.dylib has crashed" each time I try and open octane's live viewer window in C4D. I've tried opening with a simple default primitive model to make sure it wasn't a 3D model issue, but it still crashes and send me the error. Can anyone help me?
Plugin Error
C. RAM Capacity (i.e. 6 GB)
Have you set plugin accordingly to readme.txt? What you see in console window when C4D is loaded? I can't see your bugreport.zip here.
- Kham.lewis
Thanks for the reply back. When I open the console window in C4D I see the following:
Loaded Octane DDL:OctaneRender 3.05.3 version:3050300
Octane Render for Cinema 4D 3.05.3
Octane Render SDK version: 3.05.3
I followed the readme.txt fill exactly, but I still get an error. Is there a way that I can send you my bug report?
You can attach a zip version to you messages. I think it's a hardware related issue not a bug. What happen with standalone? Can you render material previews in there?
- Kham.lewis
I can render material previews in the standalone version. As far as hardware goes, I've been a doing projects using Octane with my current hardware set up for a few months. When I did a fresh install of my macOS system a few days ago, I began to get errors alerts from Octane. I've attached the bugreport.txt file as well as a screen capture of the message I receive.
- _BugReport.txt.zip
- (18.38 KiB) Downloaded 264 times
Same plugin and different OS. I have no experience with Sierra. Here only thing i can see that's a crash on environment codes. My suspect is your OS and drivers.
- Kham.lewis
Hmm. I was using this version of Octane on macOS Sierra before with minimal hiccups. I'll double check and make sure all drivers are up to date and do a few test on my end. I'll keep you updated this week.
Thank you for your help thus far
- Kham.lewis
I'm back. So, apparently Octane for vC4D 3.04.5-R2 and the Octane standalone V3.04.5 work much better. I suspect that the latest version of macOS Sierra, my graphics card CUDA version and the latest version of Octane play nicely on my machine.
It's not a solution. Have you checked 3.06-test3?Kham.lewis wrote:I'm back. So, apparently Octane for vC4D 3.04.5-R2 and the Octane standalone V3.04.5 work much better. I suspect that the latest version of macOS Sierra, my graphics card CUDA version and the latest version of Octane play nicely on my machine.
- Kham.lewis
No, I haven't checked 3.06-test 3. The latest I have access to in the download section is 3.05.3 (R1) and 3.05.3 (Standalone version).aoktar wrote:It's not a solution. Have you checked 3.06-test3?Kham.lewis wrote:I'm back. So, apparently Octane for vC4D 3.04.5-R2 and the Octane standalone V3.04.5 work much better. I suspect that the latest version of macOS Sierra, my graphics card CUDA version and the latest version of Octane play nicely on my machine.
