material conversion with opacity maps buggy?
paride4331
Hi Philips1980,
instead merge your max file, you open it, does issue occurs?
Philipp1980
Hi Paride,
yes, if I open my Octane V2-scenes first and let Octane convert the whole scene, then the conversion works. Afterwards I can save the file (which is now Octane V3) and merge objects from the scene into new scenes.
But as I noticed today: the same problem still occurs with opening one of my old material libraries. All materials are rendered white (see picture attached).
Am I the only one with this problem? Can you guys open old material libraries and they are converted correctly? I am a bit desperate... :cry:
Octane Material library bug.jpg (110.28 KiB) Viewed 3289 times
muski
Philipp1980 wrote:Hi Paride,
No you are not alone. It's frustrating that little bugs like this are not being properly checked before being released. I understand that the programmers have a lot of pressure to get things out but many of us actually need octane for paid jobs with real deadlines and stuff like this doesn't help.
On my scenes I get the same situation where if I open a v2 file the conversion happens but when I merge a v2 file materials come out blank. Also "RGB image" maps convert fine but not "greyscale image" ones.
Hope this helps to fix it.
Cheers
using octane since the dawn of the dinosaurs :)
epoimran
i have the same problem. manually converting assets is a major pain. would love for this to be fixed.
paride4331
Hi guys
I checked the issue you reported but I have not encountered problems, obviously using the converter tool;
everything seems to work well, except v2 .mat libraries.
I'm testing next 4.31_3.06 right now, so I can not tell if this is because I've not issue with V2 scene.
So, if you could be kind to share a test scene where you have the issue, I will test it.
paride4331
Hi guys,
I was wrong, the V2 .mat have no issue, the converter works fine (obviously using the converter tool..)
as already mentioned, I'm testing next 4.31_3.06 right now, so I can not tell if this is because I've not issue with V2 scene.
So, if you could be kind to share a V2 .mat library where you have the issue, I will test it.
franchais
Hi, might be off topic but I've recently purchased octane for 3dsmax, could anyone tell me how I could convert all materials to octane?
I'm also slightly new to max, currently teaching myself.
I7 2600k | EVGA gtx 680 FTW 4gb | Win 7 x64 | 16gb RAM
Return to “Autodesk 3Ds Max”
