Yes as i expected. More important that's well with heavy scenes with lot of small objects. Plugin was stressed much in this cases mostly. I did an improvement on plugin side. Evaluation of meshes are Renderer side.eyeonestudio wrote:YES. Effective when the number of objects is largeThanks...
Version 3.06-TEST-3.1 (WORK IN PROGRESS BUILDS)
pfouu
crazy improvement !!!
work great with scène with végétation scattering !!!
Bravo
Bravo
pxlntwrk.net
pxlntwrk.net
sounds very good
- eyeonestudio
- Contact:
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
- fatfreemedia
- Contact:
For the scenes I'm working on it seems to be either as fast as or faster than the stable branch, would you like a log sending over?
Win10 64bit | 3 * GTX970 | i7 5930k | 32GB
Win10 64bit | 2 * GTX970 | i7 4790k | 16GB
Win10 64bit | 3 * GTX980 | i7 5930k | 32GB
Win10 64bit | 3 * GTX980 | i7 5930k | 48GB
Win10 64bit | 3 * GTX1070 | i7 6850k | 64GB
Yes that's fine! Another trick that i'm testing is for using the Octane's texture caching mechanism. See my tests.fatfreemedia wrote:For the scenes I'm working on it seems to be either as fast as or faster than the stable branch, would you like a log sending over?
https://vimeo.com/206517639
- fatfreemedia
- Contact:
Hmm, actually on further investigation c4d seems to lock up when there's a lot of data to send to the GPUs, for example when switching between takes. Here's the most recent log: http://pastebin.com/GbPbjrng
I don't have a big scene with takes.fatfreemedia wrote:Hmm, actually on further investigation c4d seems to lock up when there's a lot of data to send to the GPUs, for example when switching between takes. Here's the most recent log: http://pastebin.com/GbPbjrng
