Version 3.06-TEST-3.1 (WORK IN PROGRESS BUILDS)
eyeonestudio wrote:YES. Effective when the number of objects is large :D Thanks...
Yes as i expected. More important that's well with heavy scenes with lot of small objects. Plugin was stressed much in this cases mostly. I did an improvement on plugin side. Evaluation of meshes are Renderer side.
pxlntwrk
pfouu
crazy improvement !!!
work great with scène with végétation scattering !!!
Bravo
pxlntwrk.net
desire
sounds very good
eyeonestudio
C4D R2026 / Win11 / AMD TR WX Series / 256Gb RAM / RTX 5090 FE / 100GbE
DinoMuhic
eyeonestudio wrote:
yeah I noticed the same but you can use the little mouse icon button next to the input field and point to the camera then it works.
fatfreemedia
For the scenes I'm working on it seems to be either as fast as or faster than the stable branch, would you like a log sending over?
Win10 64bit | 3 * GTX970 | i7 5930k | 32GB
Win10 64bit | 2 * GTX970 | i7 4790k | 16GB
Win10 64bit | 3 * GTX980 | i7 5930k | 32GB
Win10 64bit | 3 * GTX980 | i7 5930k | 48GB
Win10 64bit | 3 * GTX1070 | i7 6850k | 64GB
lucioing
Ahmet... the greatest!
L.
Mac Pro 5.1 -16 GB- 2 x Titan Black 6GB - Titan Z - MacOS Yosemite 10.10.4
fatfreemedia wrote:For the scenes I'm working on it seems to be either as fast as or faster than the stable branch, would you like a log sending over?
Yes that's fine! Another trick that i'm testing is for using the Octane's texture caching mechanism. See my tests.
https://vimeo.com/206517639
fatfreemedia
Hmm, actually on further investigation c4d seems to lock up when there's a lot of data to send to the GPUs, for example when switching between takes. Here's the most recent log: http://pastebin.com/GbPbjrng
fatfreemedia wrote:Hmm, actually on further investigation c4d seems to lock up when there's a lot of data to send to the GPUs, for example when switching between takes. Here's the most recent log: http://pastebin.com/GbPbjrng
I don't have a big scene with takes.
Return to “Releases”
