For some reason I can't get a background object to render. I know I know, select the alpha channel box. It's not working. I've used it many times before without issue. Am I missing something obvious or is something actually wrong here? I've attached the file.
Joey
Background Object Not Rendering
- backgroundtest.c4d.zip
- (85.5 KiB) Downloaded 183 times
Not sure if this is the only solution, but it looks like it needs content and not just a color.
I tried loading a jpeg into your material and it loads show fine. If you want that color, maybe create a jpeg in photoshop with that red and load that into the color channel.
OSX 10.12.4 | Intel 12 core @ 3.33 ghz | 128 gb ram | NVIDIA GeForce GTX 1080TI | Ubuntu Linux slave with 3x 1080ti
Day of background questions
viewtopic.php?f=9&t=59843
Ah ha! Originally I was using a video. I found out that wouldn't work after i started using the solid color as a test. Turns out that doesn't work either. I put in an image sequence and it works great.
So, good to know: background object must contain imagery.
Not just images. Also c4d shaders are possible but no video files.wafflelad wrote:Ah ha! Originally I was using a video. I found out that wouldn't work after i started using the solid color as a test. Turns out that doesn't work either. I put in an image sequence and it works great.
