Hey Juanjo, I wanna toss this out there, while you (we) wait for 3.0.6...
When we have a bunch of pbr textures plugged into material nodes, and we are using Octane Projection > Mesh UV, it can be kind of a pain in the ass to have to hook up Scalar nodes to all the Scale U and Scale V inputs, when we want to tile seamless maps (from Substance etc) on our UV'd surfaces... even more so when we have a buttload of surfaces to set up...
Is it even remotely possible that you could make a button for us in Octane Projection: Mesh UV, that we could click > one LW Scalar node gets placed in the Node Editor > Scalar node plugs itself into all Scale U & Scale V of all Texture Image nodes that Octane Projection is plugged into? Could this be done, or do you have no way tell from inside Projection node what Texture Image nodes are plugged into it? (like one-way street?)
Edit: I guess if this was doable for you, Rotate and Translate would be highly desired too, while we were at it...
OctaneRender™ 3.0 for LightWave™ - Production build 3.05.3.0
- FrankPooleFloating
Hmm, so the main problem is that all these parameters in the Texture Image node don't have the "E" button to animate/reference them, right?
Can you attach a screengrab with the node tree that you are using in these materials?
Sorry pal. Let me elaborate. When I have a bunch of seamless pbr texture images for Diffuse, Spec, Rough, Normal, etc, and I am using Projection Mesh UV, there is no way (that I know of) to scale all these textures in unison at the same time. With Box we can set these in the Projection Box node itself, but not in Projection Mesh UV.. so if I (and presumably others) want to scale all these Texture Image(s) together, I need to link LW Scalar nodes to all the Scale U and Scale V inputs in these 4 or 5 Texture Image nodes. It is important to point out that not all UV texturing is done at 1:1 scale. I do tons of texturing that requires UVs, but at the same time, I hit with seamless textures that are often scaled less than or more than 100%. Certainly I am not alone...
My hope was that if there was some easy way for you make these nodes and connections appear in node editor after we click the magical button I am describing, it would speed up the UV'd texture image stuff, for sure. Especially if we had one magic button for Scale(s), one for Rotation, and one for Translate(s)... I only mention this because you have added other niceties that were not needed, but sure made Octane LW even that much better, which we all appreciate and love you for buddy.
But, for we all know, LW3DG has stuff coming that would make all this moot and unnecessary. And/or maybe even Octane OSL... If you are privy to information from LW3DG that would indeed make this request moot in the near future, please do tell.
EDIT: Or better yet, find a way to somehow override the disabled/grayed-out controls inside Projection Mesh UV and allow us to scale/rotate/translate right inside the node itself... I mean, why is this disabled to begin with? Is it because the assumption was that Mesh UV is always used at 100%, and thus there would not be any need to adjust these?...
Last edited by FrankPooleFloating on Sun Feb 26, 2017 7:39 pm, edited 1 time in total.
- BorderLine
Hi Juanjo,
Any idea for 3.06 delay ?
This problem is usually related to mixing old Octane.dll/Octane.dat files with a new plugin version. Be aware that now you don't need to copy any file to the LightWave/bin folder to install the plugin, so check your LightWave/bin folder to see if you have any older Octane.* file inside and remove them.
Well, if Standalone doesn't work, then the problem can be related to your computer. Perhaps you need to install the latest drivers. What GPUs are you using?
Also, if it is a new computer, to install the plugin you should try to install before the VisualC++ 2012 redistributable package:
https://www.microsoft.com/en-US/downloa ... x?id=30679
