Wrong Texture Handring
calvados
I meet serious trouble of texture handling on Hair Prop.
Show attached picture "Normal Rendering", it is my setting texture, it is same as Poser.
But after rendering of animation or after save data of this scene, this hair prop texture is wrong, show "Missing Texture on Hair Prop".
Those hair prop is same model with different texture.
Additionally, "Re Convert From Poser" dose not work correctly.
I set correct Texture setting by manually, but it is must lost by Octane, after animation rendering or scenes save.
You can down load this sense, extracted by Poser Invently format from following.
[LINK REMOVED]
This scenes is not small, sorry.
Missing Texture on Hair Prop.
Normal Rendering
Normal Rendering
Hi - when you submit a scene to me, can you pls cut the scene down to the smallest possible size which contains the props/figures which demonstrate the problem.
I'm unsure where this error is coming from. Can you post a screenshot of the error pls?
As a quick fix, if you rename the BerlinHair prop from Victoria4 (and the other figures) to BerlinHair2, BerlinHair3, etc, then reconvert the hair materials for those props, it fixes the problem.
calvados
Thank you for your response.
Basically, Poser rename Berlin Hair Prop name, it has post fix number, 1, 2 and or.
Are you mean it make Prop name by Manually?
In this scenes, you can find lot of same Object, it is V4, cloth, and others.
Almost same object as Figure, not Prop.
Yes, rename the hair prop the make the name unique.
calvados
Thank you for your support.
It is work normally, by prop name manual change :D
Elvissuperstar007
Return to “Poser”
