Being plagued by constant crashing so I've collated all the evidence to help you detect whats going on. I payed a lot of money for a duel 1080 rig just for Octane, coming from a Mac with an eGPU, thinking it would be like heaven compared to the issues I was having before..However, this is not the case as I'm having more issues to the point where I cant work anymore. First sign is when I'm working and material previews render distorted.
So first my materials go then my live viewer stops working. An actual render doesn't even start...The whole thing just stalls...Then after a few attempts at resending scene Cinema crashes, I either get a plugin error or it completely freezes up making me force quit Cinema via task manager.
Material preview
I'm on octane VR and pay monthly.
Windows 3.03.4 - R2
Standalone
Windows 3.03.4 x64 Installer
My nvidia drivers are up to date..My Specs are in my signature.
SLI is off. Bug report ZIP from one of the many crashes is in attachment. I can send as many of these as you want as I only get a few minutes of working before crashing.
Additional questions would be is the Octane VR not worked on as much, would I be better off paying for a full license because I cant really use this for much unless I save every minute and accept the constant crashing.
Hope this is everything you need.
Constant crashing
C. RAM Capacity (i.e. 6 GB)
- mikeadamwood
- _BugReport.zip
- (35.49 KiB) Downloaded 239 times
Windows 11 Pro | ASUS Pro WSX80E | AMD Threadripper Pro 5975WX 32-Core | 256GB Micron 8x32GB 3200MHz ECC | 2x PNY RTX6000 ADA
Have you tried without external gpus and different drivers and plugin versions? Did you removed unnecessary plugin files after extract the files?
- mikeadamwood
No you've misunderstood, the eGPU was before I got my purpose built duel 1080 rig, the eGPU is out the window I don't have it anymore and is completely irrelevant to this problem.aoktar wrote:Have you tried without external gpus and different drivers and plugin versions? Did you removed unnecessary plugin files after extract the files?
I was merely referring to my previous experience before moving to PC a few weeks ago.
Ok sorry! But my other questions are still valid.
- mikeadamwood
aoktar wrote:Ok sorry! But my other questions are still valid.
I can only use the Octane VR plugin which is available to me via the subscriptions tab in my account...I am unable to use beta versions from the forum etc... I have only installed one instance of this since setting up the PC which is version 3.03.4 - R2aoktar wrote:Have you tried without external gpus and different drivers and plugin versions? Did you removed unnecessary plugin files after extract the files?
Only other thing you mentioned was drivers...So my only option here is to roll back Nvidia drivers?
Yes rollback to different drivers. And you can find another builds under C4D/Releases section. For example: viewtopic.php?f=85&t=58047
Your errors(corrupt pixels) looks like something is wrong on hardware or related things on deep level. Not in plugin codes.
- mikeadamwood
I've tried with benchmarks and everything works perfectly from the GPU side in that regard... I am going to roll back drivers now but I don't have much hope.
Could you give more information on what hardware issues it may be? I'm going back to the builders and I need as much info as I can give them.. Because for me Octane is the only thing giving me issues. Could it be pascal related?
I'm really stuck here.
have you tried 3.05.1 with correct installation?
- mikeadamwood
Yes I removed all files then did a fresh install of both latest Standalone and C4D 3.05.1 plugin from link you provided. I started on a new scene and it worked for abit, but then got the same problem where the material screwed up and my live viewer crashed.aoktar wrote:have you tried 3.05.1 with correct installation?
- mikeadamwood
Uploaded a video of crash after installing 'GeForce 368.25 26.5.2016' this is after using DDU (Display Driver Uninstaller) to get complete removal of driver, then did a clean install with older driver.
http://sendvid.com/embed/3huq2me6
This is unusable...I understand you may blame this on hardware but this GPU is working absolutely fine in other areas so cant see how it could be hardware related, at least I have no other proof of this being the case.
