light and shadow catcher
ura
when the light on the shadow catcher appears this artifact
I want to use light and shadow catcher. But I can not do that.
Hi ura,
the shadow catcher option is the old way, now we have Render Layers passes with much more options:
https://docs.otoy.com/manuals/products/ ... er-passes/
ciao beppe
ura
All this is great! But now my scene looks like.
5 cameras to 7 materials. 35 finished images to be obtained without post processing.
It is unfortunate that this bug will not be removed :(
Hi ura,
sorry but from your screenshot, I'm not able to understand exactly your issue.
Could you explain it a bit more, maybe with a simple example scene?
ciao beppe
ura
0001.orbx
(36.13 KiB) Downloaded 174 times
ura
the problem has not disappeared
ura
bepeg4d wrote:Hi ura,
The attachment 0001b.orbx is no longer available
how is it to add layers to obj?
Hi ura,
the obj mesh is connected to an "Object layer map" node that exposes the object layer pins of the connected geometry.
ciao beppe
ura
ciao beppe
it is not clear how it works
