Particles and Scatter node
I think I know what the problem is. The parser I am using for the float value is culture aware. So in Germany your decimal separator is a comma, not a period. Unfortunately, this knowledge won't help because I treat a comma or a space as a value separator. I will have to issue a new fix to use an invariant culture parser instead.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Yes, this make sense
http://www.thomas-schwenke.me
Houdini 20.5 || Win11 || i7 + RTX3080
Changed the culture setting to "point" replacing "comma." Now it works as expected
Great, works like a charm now
Will test it thoroughly, but right now, it works great!!!
Ok, works great. Here are some errors I noticed.
- Animation: When rendering in Animation mode, the image index does not go up. It stays at the same index. So, creating an animation is not possible.
- Time slider: When selecting another object, the image index will not update (go up or down). Only if the particle sphere is selected, the image index will update.
- Shader: When creating a new shader for the particles, Carrara will crash if OR Viewer is open.
Apart from these errors, it works really good
Best wishes,
Thomas
Best wishes,
Thomas
Apart from the small problems above, works really great. Thanks Simon!
Thx
These issues should now be addressed: viewtopic.php?f=79&t=56881tschwenke wrote:Ok, works great. Here are some errors I noticed.
Best wishes,
Thomas
