Animatable aperture in camera roll out
Sub forum for feature requests etc
coilbook
Please add animatable aperture and other options in octane camera roll out. We use regular camera because creating octane camera you have to redo all settings done in octane render camera roll out. Or at least a sync button that syncs all camera options with octane render cam roll out
paride4331
Hi coilbook,
I do not think I understand about "octane camera roll out".
Could you please give me some more explanation and attach screehshots also?
coilbook
paride4331 wrote:Hi coilbook,
hi i attached the image thank you
thekwen
animable focal depth could be cool too ...
paride4331
Hi guys,
they seem to work well with 3dsmax camera.
Why you do not use the camera Octane?
it also works well in animation, post processing, f-stop, etc you can animate them in 3dsMax timeline.
Screenshot attached scene
01_.zip
(280.43 KiB) Downloaded 238 times
coilbook
paride4331 wrote:Hi guys,
we do not use octane camera because every time we create octane camera all settings are defaulted and do not match octane render dialog settings Can we get at least sync octane camera settings to octane render camera settings
thekwen
Hi coilbook,
May be this could help:
1/Make a reference octane camera.
2/make a copy of this cam (to not loose the ref cam)
2/Select camera (without target)
3/In perspective view use ctrl+c (it will move you're ref octane cam to match the pers view)
Anyway a "sync button" or "paste tonemap to camera" button is a good idea ...
paride4331
Hi coilbook,
I'm sorry to contradict you, but every time you create a new Octane camera, it has the previous Octane camera settings.
But, I personally find the connection between Octane Renders's camera/imager settings, via Render Setup window, and camera/imager, in the 3dsMax's object modify, unintuitive and chaotic.
As for perspective correction, now works, I hope new developers will fix it better than now, and as soon as possible.
Return to “User Requests”
