Np. I'm looking for this issue. To put a control for negative values can be a good idea.sdandrus wrote:OK, good to know. Thanks for the quick response! As for the other post I made I dont remember what the outcome was. Ive been insanely busy but I must have figured it out!
Camera Shaking violently when rendering with octane?
- zhollifield
I've got the same issue. It will randomly render with a shaking camera. When I re-render, it works fine.
Propably it's about very low coordinates or target distance values. Renderer run on single precision float-math. This can cause math errors.zhollifield wrote:I've got the same issue. It will randomly render with a shaking camera. When I re-render, it works fine.
Create a default camera and put under your camera and test it again.
- zhollifield
Making a new camera and placing it as a child of the bad camera seemed to work. Thank you.
- fuelnewmedia
It definitely is a bug related to focus distance.
Simply set the focus distance of the C4D camera to 0, and you'll have a wildly shaking rendering.
Best regards,
Best regards,
I don't suppose that's a BUG. Most likely a limitation of single-precision math. You may try to change ray-epsilon and check if it fixes that.fuelnewmedia wrote:It definitely is a bug related to focus distance.
Best regards,
