Volumetric Stage Lighting
tartanpimpernel
trying to replicate the look of the lighting juanjgon created for C4D & LW but just cant get anything close to it using 3dsMax
viewtopic.php?f=36&t=53505&p=269975&hil ... ax#p269975
anyone have any ideas ?
i7 3930k @ 4.2ghz | 32gb | GTX Titan | win7 x64 | Octane 3+
i5 4670k @ 4.1ghz | 32gb | GTX 670 4gb | win10 x64 | Octane 3+
paride4331
Hi tartanpimpernel,
This link might help you.
viewtopic.php?f=21&t=56599
Let me know your news.
tartanpimpernel
Thanks for the thread link paride4331 much appreciated
unfortunately I need the light cone effect to come from several different sources (lights)
paride4331
Hi tartanpimpernel,
just change the emitters, the rules are the same about it.
attached a file with the scene shown in screeshot.
fog2.zip
(42.53 KiB) Downloaded 329 times
tartanpimpernel
Thanks for the help paride4331, I had been using an ies opposed to a Sun and wasnt getting anywhere
just need to tighten up the contrast to the edge of the light volumes, drop some of the grain out and I'll be pretty much where I was hoping to be for my little project
has highlighted I really need to set some time aside and learn more about lighting
thanks again
paride4331
Hi tartanpimpernel,
To adjust light and volume, you can simply make it through these parameters.
tartanpimpernel
perfect, thanks ( again ) paride4331
will have a proper look at things on the weekend
Rico_uk
Something that I usually do to achieve direct light style spot lights, especially when looking to get volumetric spotlights like stage lights is to create a cylindrical mesh around the light to funnel the light. Works really well with pathtracing but also for direct light kernel. You can either make the cylinder cone shaped to remove the rays that aren't travelling directly forward or you can make the cylinder a lot longer in front of the light to achieve the same effect.
acc24ex
that last solve is a bit basic, but it seems to fit the real life situation, you basically built a reflector/flood light, just realised this could be achieved relatively painlessly through a max script .. or some object asset library (which I'm still on a lookut for a good one)
Return to “Autodesk 3Ds Max”
