OctaneRender™ Standalone 2.25
manalokos
You guys could make an update to 2.xx version so the autentication method would be compatible with the 3.xx licenses.
mojave
You should already be able to activate 2.xx using Octane V3 licenses but obviously not the other way around.
blackshore
When are you adding pascal support for 2.x (1000 series)?
The Cuda Toolkit 8 is already out. Is it not just to recompile with the new tool-kit?
abstrax
blackshore wrote:When are you adding pascal support for 2.x (1000 series)?
Will do that next week.
nuno1980
abstrax wrote:Will do that next week.
ok but I really want you modify max samples per pixel from 256k to infinity (0 as continuous)!!
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ViewSonic XG2431 24" :D
blackshore
Thank you! :D
abstrax
We will bump it up to 1000000 samples/pixel. Anything beyond that doesn't make sense since the limited numerical precision will make that addition of a small number to a large number have no effect. I.e. at that point, additional samples will be calculated, but not recorded in the film buffer anymore. If you really need more samples/pixel, you should probably fix your scene (anything beyond 40000-50000 samples/pixel is already unusual) or use a different render engine since Octane is then obviously not able to render this scene in any reasonable amount of time. If you insist on using Octane and going beyond 1000000 you could render multiple images and save them as OpenEXR images and then stack them in Photoshop or something similar.
nuno1980
abstrax wrote:We will bump it up to 1000000 samples/pixel. Anything beyond that doesn't make sense since the limited numerical precision will make that addition of a small number to a large number have no effect. I.e. at that point, additional samples will be calculated, but not recorded in the film buffer anymore. If you really need more samples/pixel, you should probably fix your scene (anything beyond 40000-50000 samples/pixel is already unusual) or use a different render engine since Octane is then obviously not able to render this scene in any reasonable amount of time. If you insist on using Octane and going beyond 1000000 you could render multiple images and save them as OpenEXR images and then stack them in Photoshop or something similar.
Ok but "continuous" is especial for normal caustics or sharp caustics at dot/thin light, at our sun, at light laser... If the noises aren't good and/or the caustics rendered are less visible than real-life at 256k spp for caustics only then I really want "continuous"(when the image gets few noises or almost no noises, I'll pause to render ;)) from 256k spp.
But I don't deserve "caustic blur"!
Still noises despite 256k spp - example is https://blenderartists.org/forum/showth ... -in-Cycles - about glass' spheres and mirrors in fog -> follow I'm nuninho's user
NOTE: I don't care animation but yes few images rendered. ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
smicha
1 000 000 is not enough Nuno? :shock: :roll: :roll: :roll:
nuno1980
smicha wrote:1 000 000 is not enough Nuno? :shock: :roll: :roll: :roll:
Probably yes at our sun but if we get still noises then we try more spp. ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
Return to “Commercial Product News & Releases (Download here)”
