OctaneRender for Carrara 3.03.04.23[Stable]
Carrara (Integrated Plugin developed by Sighman)
Sighman
I don't know any more than what's posted on the public forums. I beleave its on the roadmap but I have no idea when or what it's priority is.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Sighman
New update posted to this tread to address a baking camera bug.
Tugpsx
Thanks again for update. Playing around again and found that when the render room is set to Octane integrated viewport, if I switch views before the sampling is completed I get a request to stop the render. When I choose not to stop the render the render viewport disappears and there appears to be no way to get it back but to render again. is there a way to access the progress bar yet, since it shows 100 percent completed when its still sampling.
Sighman
Tugpsx wrote:Thanks again for update. Playing around again and found that when the render room is set to Octane integrated viewport, if I switch views before the sampling is completed I get a request to stop the render. When I choose not to stop the render the render viewport disappears and there appears to be no way to get it back but to render again. is there a way to access the progress bar yet, since it shows 100 percent completed when its still sampling.
I'll look into it but don't get your hopes up. I had to shoehorn octane into the render room as it is. It is not very robust and should only be used for batch rendering and rendering .avi files. Always use the ORVP window for still rendering and rendering animations to individual files.
Tugpsx
Thanks, for quick reply. Looking forward to your progress.
Sighman
A new update has been posted here: viewtopic.php?f=79&t=56881
protovu
Hi Simon,
2 problems:
I have a material which is not allowing any Octane UV transform. Oddly, it does allow Carrara UV transform.
The same crosshatch bitmap does work in other Octane Materials. I will work around, but would like to know how to correct the existing Material instead of swapping it out.
Separately, I am not able to update to the latest, per attached.
thanks for your help,
Rick
noUVtransform.zip
(31.09 KiB) Downloaded 421 times
Sighman
Make sure Carrara is not running when you install.
protovu
Sighman wrote:Make sure Carrara is not running when you install.
Yep..sure enough was the problem.
Was able to install, but not able to use. Kept crashing on polygon selection in vertex model room.
protovu
Hi Simon,
Having the same issue with multiple keyframe selection again. Narrowed it down to one Material. Deleting the Material, stops the problem. Haven't done much to the material, other than add a name.
Can you please take a look?
Rick
no marquis.zip
(5.38 KiB) Downloaded 400 times
Return to “Carrara”
