half precision error
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
WhyGee
I've tried rendering half precision without multilayer EXR and I get an error "failed to export render passes discrete files".
Is this feature still not working?
Thank you!
Yaniv
juanjgon
Weird, let me check it. Anyway this feature has an internal change in the Octane API that will be included in the next plugin build, so I'll be sure that the half precision EXR files can be used without problems in the next build.
Thanks for reporting,
WhyGee
WhyGee
I'm still getting an error, this time whether half precision is selected or not, doesn't make a difference.
I don't see other people posting regarding this issue so it could be only on my end?
(on houdini 15.5.565)
can you recreate the error on your side?
render_error.rar
scene hip file
(21.95 KiB) Downloaded 242 times
octane version
octane version
error message
error message
juanjgon
Yes, sorry, I am aware about this problem, that as you say has not been fixed in the latest build.
It has been fixed now for the next build. Meanwhile you can use the multilayer EXR files, but if you need this feature now I can send to you a custom plugin build with this problem fixed.
WhyGee
Yes if you could send me a fixed build that would be great.
Thank you very much!
Yaniv
juanjgon
This is a custom build with this problem fixed:
https://render.otoy.com/customerdownloa ... _Win64.zip
WhyGee
it works now thanks again!
Yaniv
Return to “Bug Reports”
