V3 serious shading issues
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
adamnerva
And here is the cycles render, which I would describe as my expected results:
adamnerva
And here is the exact same mesh exported as OBJ and rendered in Octane Standalone. Expected results achieved. So the issue here appears to be that Octane for Blender does not read the mesh normals. Hopefully this is a trivial thing to correct.
grimm
Hi adamnerva,
Looks like you have rounded corners turned on in the Octane plugin render you posted.
Jason
adamnerva
grimm wrote:Hi adamnerva,
Jason
Actually, no I don't. And the blend file is included in the first post.
adamnerva
OK, the problem is definately that Octane for Blender cannot read vertex normals. New test file attached. This is a beveled cube with custom vertex normals.
https://dl.dropboxusercontent.com/u/276 ... Norm.blend
I consider this a pretty big bug that kills my workflow. I hope it can be addressed.
Issa
Hello my friend,
it is good ?
adamnerva
Issa wrote:Hello my friend,
it is good ?
No. That is not good. That actually completely disables the smooth shading, rendering every polygon as a facet. I need Octane to render meshes as Cycles does, and as standalone does: using the vertex normals.
J.C
This is the same in V2.x
Maybe Octane does not properly interprets edge creases.
Anyway adding Egde Split modifier solves the issue.
System – Windows 11
adamnerva
J.C wrote:This is the same in V2.x
Unfortunately, no, the edge split modifier does not solve the issue. Blender has support for custom vertex normals, which I make use of in my second example scene. The vertex normals are face area weighted. The edge split modifier cannot fix this, nor can it fix imported CAD models with very precise vertex normals.
Blender supports vertex normals. Octane standalone supports vertex normals. And Octane for Modo supports vertex normals. It was actually a huge surprise to me that Octane for Blender doesn't even have this very basic feature.
Return to “Bug Reports”
