See attachments.
https://dl.dropboxusercontent.com/u/276 ... blem.blend
V3 serious shading issues
C. RAM Capacity (i.e. 6 GB)
And here is the exact same mesh exported as OBJ and rendered in Octane Standalone. Expected results achieved. So the issue here appears to be that Octane for Blender does not read the mesh normals. Hopefully this is a trivial thing to correct.
Hi adamnerva,
Looks like you have rounded corners turned on in the Octane plugin render you posted.
Jason
Jason
OK, the problem is definately that Octane for Blender cannot read vertex normals. New test file attached. This is a beveled cube with custom vertex normals.
https://dl.dropboxusercontent.com/u/276 ... Norm.blend
I consider this a pretty big bug that kills my workflow. I hope it can be addressed.
This is the same in V2.x
Maybe Octane does not properly interprets edge creases.
Anyway adding Egde Split modifier solves the issue.
System – Windows 11
System – Windows 11
Unfortunately, no, the edge split modifier does not solve the issue. Blender has support for custom vertex normals, which I make use of in my second example scene. The vertex normals are face area weighted. The edge split modifier cannot fix this, nor can it fix imported CAD models with very precise vertex normals.J.C wrote:This is the same in V2.x
Blender supports vertex normals. Octane standalone supports vertex normals. And Octane for Modo supports vertex normals. It was actually a huge surprise to me that Octane for Blender doesn't even have this very basic feature.
