Can UV-maps be animated? (E.g. can the offset be animated?)
justavisitor
If you use Cycles, you can go into the Texture Panel and animate a UV-map's XYZ values - but that panel doesn't know anything about Octane.
So is there another way to animate transformations of a UV-map?
I've experimented with the Octane Full Transform node and other Octane nodes, but I can't find a way to make this work...
Latest OctaneRender for Blender. Windows 10, i7 quad 3.7GHz, 16GB, 2xTitan.
regionfive
You can either animate the Octane Transform node to have general access within the shader tree, or you directly animate the uv layout with the animall add on.
The increments in the transform node need to be right. try to stay between 0 and 1.
kraken
Transforming the texture is easy. Use the transform node in the node editor. It works for both image maps and procedural.
The trick for image maps is to UV unwrap the object otherwise the map will not share the coordinate space.
What baffles me is the why can't procedural textures share the object space. Doesn't matter if you unwrap the object or not. The textures
have their own space and you can't lock it to the surface.
Anyone have a solution for that?
James
Win 7 64bit Ultimate SP1
Blender 2.78
4x GTX980 Ti
NVidia Driver 373.06
Octane Server 3.03.4 v.11.2
Octane SA 3.03.4
Dual Xeon E5-2686
64 GB Ram
1TB SSD
AsRock EP2C612 WS
pegot
kraken wrote:What baffles me is the why can't procedural textures share the object space. Doesn't matter if you unwrap the object or not. The textures have their own space and you can't lock it to the surface.
+1
I have run into this as well in Octane Blender (though I was using a more complex object - a spline with a morph).
Win 10 - AMD Ryzen 9 5950X
MB: ASRock X570 Creator
PSU: 1600w EVGA
5090 MSI Suprim WC
3090 ASUS Tuff
aufwind
hi,
it works. You have to unwrap the object. Make sure you have the 'uvw projection node' plugged into the projection pin of the procedural texture.
kraken
Kudos Aufwind!!!!
Oddly I did UV Unwrap, but I forgot to save the map. That's why I was having so much trouble. Note to self: SAVE the map.
Cheers,
James
Blender 2.78
4x GTX980 Ti
Octane SA 3.03.4
Dual Xeon E5-2686
64 GB Ram
1TB SSD
AsRock EP2C612 WS
Return to “Blender”
