Network render - standalone can see my GPUs but C4d doesn't
PiotrAdamczyk
Hi
Deamons are running on both machines. I have octane standalone on both of them but i have only one c4d plugin license. For some reason standalone can see my GPU's but c4d cant see them.
Hi PiotrAdamczyk,
could you try with only Cinema 4D active on the master and one daemon active only on the slave?
What do you see in Live Viewer info after loading any kind of scene?
ciao beppe
rappet
Is your plugin version the same as your standalone (daemon)?
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
PiotrAdamczyk
Both versions of standalone and octane plugin are the same.
Do i need to have 2 octane cinema 4d plugins for network rendering to work?
rappet
PiotrAdamczyk wrote:Both versions of standalone and octane plugin are the same.
No, you only need the plugin on the master... the slaves only need the OR standalone.
PiotrAdamczyk
i have octane deamon opened on slave, all octane versions are the same, standalone sees my slave GPUs but cinema does not.
Hi PiotrAdamczyk,
that's weird :roll:
Here is a link about Octane net rendering inside c4d:
https://docs.otoy.com/manuals/products/ ... rendering/
and here is about logging for sending back to us of some log files, in order to better understand what is going on with your particular setup:
viewtopic.php?f=86&t=54503#p285541
ciao beppe
PiotrAdamczyk
thanks, it was a firewall issue, right now i have 3.02 standalone installed but i get the "invalid version" error.
Is it possible that its becouse i'm using 3.03 cinema4d plugin version?
Octane standalone sees all of my slave gpus
PiotrAdamczyk
The problem was with firewall blocking my other PC, i was also using the latest standalone version from the downloads page and not from the forum's thread you posted, thanks for the help guys.
