Bump or Normal +Displacement channel render issue?!
ldyboss
Hi
I always have a problem .
if i render just use bump map. Its OK , Just use displace maps ,its be right.
But Bump + Displacement map .Its always render some issue. You will see model's wireframe. Its not smooth shading.
Image Only Bump
Image Only Displacement
Image Both
Displace+Bump_demo.zip
(180.82 KiB) Downloaded 228 times
That's not a plugin issue. Try mix material trick and lower bump values.
red-juice
Ive been struggling with this too.
I've tried the mix material 'trick' but still getting bizarre tiling/artefacting with my Normal map when displacement is used..
Has anyone actually figured out how to do this?
has version 3 fixed this?
red-juice wrote:Ive been struggling with this too.
which textures are you using here? C4D textures?
red-juice
Im using a .tif file for displacement, and a .png for the NRM.
Havent actually considered image formats... hmmm
red-juice
It seems using different image formats doesn't make a difference at all.
So frustrated with this. :(
red-juice wrote:It seems using different image formats doesn't make a difference at all.
please put your scene so let's check it.
red-juice
here ya go:
Thanks very much. Her's a DL link to the file & textures (10mb)
https://www.dropbox.com/s/8pvkemfoo6mbl ... M.zip?dl=0
red-juice
gutted,
Guess theres no way to combine Displacement and Normals/bump in Octane...
really wished I'd researched this before purchasing. :x
Hi red-juice,
sorry for the late answer, I have missed your post with the scene :roll:
Octane Displacement is different but it works, here is your scene revisited:
Untitled_b.c4d.zip
(114.92 KiB) Downloaded 223 times
You have to enable Use displacement in the mix material and connect the normal map to the proper pin in both materials. Then set the Level of details at 2048, like the resolution of the disp texture, for better results.
If you use 32 bit displacement texture, you can have even better results ;)
ciao beppe
edit: it is very important to have correct uv unwrapped without overlapping with geometry more complex than a single plane.
