Lightwave 3D Plugin v0.2
holocube
Comes with two .obj exporters - you can switch between the two inside the Octane Exporter GUI.
  • "Lightwave HC OBJ Exporter" is Lightwave Layout internal obj writer only available in Lightwave HC (build 2013 or later)
  • "Octane OBJ Export" is written by me and windows only. For Lightwave 9 or later.
Please check the readme inside for more details and differences between the two.
!Please make sure you read both the offical manual on Plugin<->Octane workflow and the readme.txt inside this package before using this plugin.
If you have any issues please give me information what your export settings are and what you're exporting. You can reach me on skype 'walfridson' or at my mail if you want faster contact or sending me files.
v0.2e changes: sets autokey to true when rendering
v0.2d changes: bug fix
v0.2c changes: logfile output
v0.2b changes: removed 3-4 point limit, didnt know octane supports more... :)
v0.2 changes: Octane OBJ Export rewrite. Have to modes, "Normal" or "Fast". Fast is a bit more dirty but might actually fix UV problems if you have any. I recommend using "Fast"
LWOctane_v02e.zip
(264.13 KiB) Downloaded 597 times
LWOctane_v02d.zip
(263.66 KiB) Downloaded 590 times
LWOctane_v02b.zip
(257.18 KiB) Downloaded 574 times
LWOctane_v02.zip
(257.17 KiB) Downloaded 606 times
GTX260 Seven 64bit
I'm Superfrog
kggraphics
Can't wait to try this out! ;) Thanks!!
_________________
Windows 7 64 bit | Geforce GTX260 Core 216 | Core 2 Quad 2.53GHz | 6GB DDR2
http://www.kggraphics.com
geo_n
Crashing on lw hc exporter both fast and normal mode using latest lw build 2015 64bit.
lw exporter on both mode working. The fast mode is fast :lol:
Will try on lw 9.6
holocube
that's weird geo, will test when I got HC in my hands again.
Put up 0.2b
GTX260 Seven 64bit
I'm Superfrog
3dworks
tested 0.2b now again on mac. same issues. 'failed to copy obj' followed by 'failed to copy mtl'.
everytime, no matter if a single object or a more complex scene.
i'm using use all default settings, just the exporter settings are set to 'lightwave OBJ export (hc only)'.
Same issue if i use the 'export obj/mtl only' button.
LW build 2015, osx ub 64 bit, on mac osx 10.6.3.
attachments: screenshot + object which i tried to export.
box2009_real.lwo.zip
(1.2 KiB) Downloaded 515 times
Specs: Apple MacBook Pro M1 max 64GB 2TB, MacOS 12.5 / MacPro 5,1 with NVIDIA GeForce GTX 1080 8G, MacOS 10.13.6 / Mac Pro 5,1 with AMD RX5700 8G, MacOS 12.3.1 / HP Z600 with NVIDIA 3060 RTX 12G, Windows 10 pro + Netstor GPU box, 4 x NVIDIA GTX 980ti 6G.
geo_n
3dworks wrote:tested 0.2b now again on mac. same issues. 'failed to copy obj' followed by 'failed to copy mtl'.
Do you have ngons? Also I think only one layer in layout is possible for now.
3dworks
geo_n wrote:...
thanks for advice, missed that one.
however: removed layers and ngons, but have still the same issue.
geo_n
The plugin is really fast exporting this time :mrgreen: . Just notice that the camera bank angle is not supported?
Also the master plugin settings can't be saved with the lws file?
Another test
sjonsjine
I still can't use it.
Please attache simple lws/ obj/ ocs / lwo files so we can check it with your simple working project.
And please attach screengrabs of all settings.
sjonsjine
holocube
sjonsjine could you open up "edit plugins", see that you have OctaneExport.p in there with a layout command called OctaneExportOBJ ?
GTX260 Seven 64bit
I'm Superfrog
Return to “Lightwave 3D”
