EVGA GTX 780 Ti Classified failed - OR 3.0 standalone
nuno1980
Hi.
Look my specs (signature) and Win 10 x64 with CPU@4.4GHz and GFX 364.96beta.
Primary videocard: Intel HD 4600 (i7-4790K) for monitor and second videocard: GTX 780 Ti Classified for GPGPU (CUDA or OpenCL).
Log after have rendered during 10 minutes at the speed of ~5.5 MS/s:
Started logging on 24.05.16 10:39:40
OctaneRender 3.00 Demo (3000020)
CUDA error 719 on device 0: An exception occurred on the device while executing a kernel. The context cannot be used anymore and must be destroyed. All existing device memory allocations from this context are invalid and must be reconstructed.
    -> kernel execution failed (orderQueue)
device 0: PMC kernel failed
NOTE: I don't use any GPU and VRAM overclocked. :( But I'll leave my GPU to RMA in next month. ;)
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
nuno1980
2nd time with same error after 2 hours rendered with the speed of ~4.5 MS/s.
NOTE: v2.25, GPU had rendered without any problems during 60 hours.
Caustics at PT
i7-12700KF
32GB DDR4@3600
Hi nuno,
have you used the installer or the zip version for the Standalone?
Are you using displacement in your scene?
Could you share the .orbx with us?
ciao beppe
nuno1980
bepeg4d wrote:Hi nuno,
ciao beppe
I used installer (EXE) demo v3. I don't use displacement.
I've rendered "Wedding" scene. Yes, OCS file with the resolution screen of 2560x1600 (OR v2.25 full version), you may keep to auto-change to 1002x602 on demo v3.0. ;)
PS: Could be VRAM issue. ;)
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
Has your other videocard or new OR v3.00 same problem?
Caustics at PT
i7-12700KF
32GB DDR4@3600
Hi nuno,
please, could you save and share an .orbx file, an .ocs file alone is useless, and we have not time to recompose your scene.
thanks
ciao beppe
nuno1980
thanks
ciao beppe
Ok. aaah! you haven't obj, sorry. I'll try orbx.
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
look new orbx. :) But you change "local time" from 10 to 8 in daylight and you will test to render during only mimutes or hours.
wedding_2.orbx
(3.03 MiB) Downloaded 358 times
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
If @bepeg4d or @any guy gets still no GPU failed after hours of rendered then I'll leave my GPU to RMA.
Caustics at PT
i7-12700KF
32GB DDR4@3600
Hi nuno,
sorry for the late answer, I have launched your scene yesterday evening till this morning for more than 16 hours with no fails :roll:
Could you check your system when rendering with GPU-Z to see if there is something strange, maybe overheating :roll:
ciao beppe
