OctaneRender for Carrara 3.0.12.10[Beta]
Carrara (Integrated Plugin developed by Sighman)
protovu
Hi Simon,
2 more findings related to batch queue:
Basically the opposite of the previous post, that is, an object that is toggled visible at frame 1 and is toggled invisible at frame 3 will not become invisible in the batch queue render at frame 3.
Under General Tab, View, Show Object in 3D View. If an object is toggled to not show, it will not render in batch queue. It will, however, render directly through the Octane Viewport.
Thank you,
Rick
Sighman
Please try the latest update posted to this thread. viewtopic.php?f=79&t=53697
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
EddyMI3D
Great! Thank you!
My Rig:
PC with AMD FX 8350 @ 4,00 GHz
Win 7-64
Nvidia GTX 760
Nvidia GTX 970 (only for rendering)
About 6 TB of disk space (768 GB of SSD)
Octane/Octane for Carrara
protovu
Hi Simon,
Thanks for your work on this. Unfortunately, in Batch Queue, objects are still not toggling off. I have attached a file with an attempted work around using the Octane object layer modifier. It sort of works , in that the objects do toggle off , but we see that a ghost of the disappeared previous object appears on the next visible object (the objects are sharing the same space). Again, objects behave properly when rendered directly in the Octane viewport.
Best regards,
Rick
win7
dual xeon
2 titanx
1 ge980
novisibilitytoggleinbatchqueue.zip
(3.5 KiB) Downloaded 443 times
Sighman
If at first you don't succeed...
protovu
We seem to have a broken link............
EddyMI3D
My Rig:
Win 7-64
Nvidia GTX 760
rashadcarter
I am unable to download this version. Every time I try to follow the url it leads to an error message. Any assistance is appreciated. Thanks.
rashadcarter
I'm an idiot sometimes. Solved the download link issue. No worries.
Sighman
Fixed link...
Return to “Carrara”
