Hi Simon,
2 more findings related to batch queue:
Basically the opposite of the previous post, that is, an object that is toggled visible at frame 1 and is toggled invisible at frame 3 will not become invisible in the batch queue render at frame 3.
Under General Tab, View, Show Object in 3D View. If an object is toggled to not show, it will not render in batch queue. It will, however, render directly through the Octane Viewport.
Thank you,
Rick
OctaneRender for Carrara 3.0.12.10[Beta]
Please try the latest update posted to this thread. viewtopic.php?f=79&t=53697
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Hi Simon,
Thanks for your work on this. Unfortunately, in Batch Queue, objects are still not toggling off. I have attached a file with an attempted work around using the Octane object layer modifier. It sort of works , in that the objects do toggle off , but we see that a ghost of the disappeared previous object appears on the next visible object (the objects are sharing the same space). Again, objects behave properly when rendered directly in the Octane viewport.
Best regards,
Rick
win7
dual xeon
2 titanx
1 ge980
Best regards,
Rick
win7
dual xeon
2 titanx
1 ge980
- novisibilitytoggleinbatchqueue.zip
- (3.5 KiB) Downloaded 424 times
If at first you don't succeed...
This address was fine for me: https://render.otoy.com/customerdownloa ... .0.0.9.exe
My Rig:
PC with AMD FX 8350 @ 4,00 GHz
Win 7-64
Nvidia GTX 760
Nvidia GTX 970 (only for rendering)
About 6 TB of disk space (768 GB of SSD)
Octane/Octane for Carrara
Win 7-64
Nvidia GTX 760
- rashadcarter
I am unable to download this version. Every time I try to follow the url it leads to an error message. Any assistance is appreciated. Thanks.
- rashadcarter
I'm an idiot sometimes. Solved the download link issue. No worries.
