Playing with atmospheric
enricocerica
Some images as a result of testing the scattering medium on environment.
Modeled with Blender
Rendered with Octane Standalone 3.00 alpha 8
Path tracing kernel
Modeling system : I7 32GB Windows 10 & Fujitsu Celsius H720
GPU : 1x Gigabyte GTX580 3GB + 1x MSI GTX780 3GB + 1x PALIT GTX780 6GB +1x Asus Stix GTX1070 8GB
http://www.myline.be
nuno1980
No create a box needed for fog? Has new OR v3 standalone fog option (IMPORTANT: do not forget to the fog be not inside the specular material)?
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
whersmy
YES ENRICO
rendertimes? :)
Octane 2022.1.1 nv535.98
x201t - gtx580 - egpu ec
Marvez
real Art
(and render times?)
I7 5820K 16MB RAM SSD850PRO GTX 970/780
enricocerica
Thanks Guys,
Render time is about 3h on 2x gtx580 & 2x gtx780 in 3600x2400
nuno1980
Should respond my question because you may blind it...
Caustics at PT
i7-12700KF
32GB DDR4@3600
enricocerica
nuno1980 wrote:No create a box needed for fog? Has new OR v3 standalone fog option (IMPORTANT: do not forget to the fog be not inside the specular material)?
You don't need to create a box anymore, just select the right option in the environment panel, slide parameters and that's it ;)
nuno1980
enricocerica wrote:You don't need to create a box anymore, just select the right option in the environment panel, slide parameters and that's it ;)
Thank you! :D But the fog is in all environment except any specular material as glass, water..., ok?
Caustics at PT
i7-12700KF
32GB DDR4@3600
nuno1980
If you've "Octane Render Team" then you should ALWAYS respond my question. And I'm confused.
Caustics at PT
i7-12700KF
32GB DDR4@3600
