Invert falloff node in opacity
Andygraph3D
How can i make it ?
Set the Opacity node type to Invert, and set the Invert Texture pin to a Falloff Map. Try Normal = 1, Grazing = 0 for the Falloff Map.
Andygraph3D
its the same don't change :-(
It works fine for me. What render effect are you trying to achieve?
Andygraph3D
I managed to do that effect putting on normal 0.5
and using a ball ... but I can not with this prop to have the same effect :-(
this is what I want to achieve.
You need to use the opposite\Grazing and Normal values to what you are using to get that effect.
Andygraph3D
how, is there a node ?
Can you to explain how i can to do it ?
Pls see image below...
Andygraph3D
sorry Paul, try you on this prop ...
That prop is very flat, so you there are virtually no glancing polygon to give you the effect you want. You need to make the prop more spherical. Or use an opacity map.
Return to “Poser”
