How do I create IES light?
Moderator: BK
- morphious2013
I have the IES profiles, just can't figure out how to add them into octane plugin. Do I need to create an emitter, then ad it in the materials node? If so, where? Thanks.
Gateway i5 3.2ghz, 16g RAM, GTX 690 4GB VRAM, Windows 10 64bit, Poser Pro 11, DAZ Studio Pro 4.9, Daz Octane Plugin V2, Poser Octane Plugin V2
- linvanchene
face_off updated the OcDS projection mode names to be identical with the OR standalone version in one of the recent updates.morphious2013 wrote:I have the IES profiles, just can't figure out how to add them into octane plugin. Do I need to create an emitter, then ad it in the materials node? If so, where? Thanks.
Now you can follow those steps:
001 Create a Basic Light emitter with the green y normal direction pointing down on the ground.
002 Change the Distribution setting of the emitter material to a grey image
003 Select one of the IES presets that are shown in the pulldown menu of the grey image node in the distribution setting.
Now you have three options how to proceed:
004A by default the Mesh UV Projection should now be selected
The Mesh UV Projection will create exactly the same light pattern on the floor as in the preview image IF the light emitting plane is pointing with the green y axis normal facing down towards the floor plane.
Note that with Mesh UV Projection the IES light pattern is cast directly below the emitter on the floor no matter in which direction the normal of the light emitter is pointing.
If you want to point the IES light pattern into a specific direction
004B change the projection mode of the IES image in the distribution channel to XYZ to UVW Projection
As Coordinate Space select "Normal Space (IES Lights)"
Now you can point the green normal y axis of the light emitting plane in the direction you want the IES light pattern to be cast.
Alternatively
004C change the projection mode of the IES image in the distribution channel to Spherical Projection
For the sake of it have a look at the pattern with the light emitting plane normal facing down.
-> Spherical Projection can be used to get the same result as Mesh UV Projection.
I guess it is also a matter of preference or creative choice which projection mode you prefer for the effect you want to achieve.
Also compare:
Projection modes
https://docs.otoy.com/#51Texturing%20Wi ... on%20Nodes
Mesh emitters
https://docs.otoy.com/#51Mesh%20Emitters
Added the test scene in .duf and .orbx format in the .zip
Special thanks to Vinz who created, updated and shared the IES presets included in the OctaneRender plugin for DAZ Studio.
originally posted in 2011:
viewtopic.php?f=9&t=6157&start=10#p52161
- IES lights v1001.zip
- test scene in .duf and .orbx format
- (38.71 KiB) Downloaded 1605 times
Win 10 Pro 64bit | Rendering: 2 x ASUS GeForce RTX 2080 Ti TURBO | Asus RTX NVLink Bridge 4-Slot | Intel Core i7 5820K | ASUS X99-E WS| 64 GB RAM
FAQ: OctaneRender for DAZ Studio - FAQ link collection
maybe i should stick on this thread
i asked that question to liva already and not even he got an easy answer, but maybe someone else knows...
has someone ever tried to "copy" the standard 3dlight conelights in octane? to make it look like in those old but gold 3dlight standard renders? i tried alot but i never got it even close... no idea how to get shadows that sharp and so on...
anyone can provide some hints or adjustments maybe?
my trial lights have been made from a cone object
- morphious2013
Revisited. Should I not be able to "see" the light rays? I only see the surface the light is striking. ???
