OctaneRender 3 for Revit [OBSOLETE]
Autodesk Revit (Integrated Plugin developed by Paul Kinnane)
Garquitectos
Hi Paul, to change the focal lenght you must right click in the complete steering wheel, and then you can modify with the mouse.
Octane Render for Archicad, Archicad 16 Spanish, Bimx. - Win 7 64 bits - Intel core i7 870 - 3,30 Ghz, - 12 Gigas Ram - GTX 660 + GTX 650 Ti
http://www.garquitectos.es
http://garquitectos.wordpress.com/
Hi Paul, to change the focal lenght you must right click in the view complete steering wheel, and then you can modify with the mouse.
Thank you. Setting the Octane Focal Length from the Revit Focal Length is an excellent suggestion. However unfortunately the Revit API does not provide any means to get the Revit view Focal Length - so it does not appear to be possible to implement this.
Garquitectos
In the new V-ray plugin works... I dont know how they have implemented but it's working.
The same view with diferent focal lenght.
Many thanks! I'm sure you can implemented ;) Its very usefull
3.0.3.38
- Compiled with Octane 3.0 alpha 3
- Fixed issue where refreshing the Viewport after changing a proxy was causing a Exception. You can now no longer refresh the scene whilst the Geometry Proxy Details dialog is open.
- When adding a family instance to the scene which has a proxy default, the "Is A Proxy" button will now be set correctly, however the material will still not be available for editing until the Viewport is next opened or the scene is Refreshed
I have posted the question as to how to get the Focal Length on the Revit API forums. I will let you know if I get a response.
Garquitectos
The revit api is not the "best" in the world... :lol: I searched about it and I have found nothing...
I have refreshed the installer at the top of this thread with:
3.0.6.38
- Compiled with Octane 3.0 alpha 6. Note the minimum Nvidia driver required is 353
Seekerfinder
Thanks Paul
Garquitectos
Paul is posible a Revit 2017 version? :roll: Thanks in advance!!!
Below is an installer for the Revit 2017 version. There were quite a lot of changes needed - so I suggest testing it thoroughly prior to using it on production scenes.
https://render.otoy.com/customerdownloa ... _Win64.exe
Return to “Autodesk Revit”
