Octane Medium Help
Moderator: BK
3dmania
Hello,
I am now using the 3.0 plugin and I was wondering on how I can make volumetric effects with the new system. Is it still the same way that the camera needs to be outside the object?
Environment tab, Medium->set to SSS, Scattering = white, Medium Radius try 20, adjust the effect with the SSS Scale.
TRRazor
Try a Medium radius of 20, as face_off suggested.
Set the Medium density to 0.3 - this should give you a good starting point :)
W10 64 bit | i7 3770K | MSI Geforce RTX 2080 (8GB) + GTX Titan Black (6GB) | 32 GB DDR3 RAM
Veneris
....and to create god rays as it make (in OC for DAZ Studio)?
Like this:
https://www.youtube.com/watch?v=MqOZp77ZSLg
or
http://www.daz3d.com/atmocam-for-iray
Intel Core i5-2500 CPU @ 3.30Ghz (Quad Core), 12.0GB RAM, NVIDIA GeForce GT 620. Windows 7 (64 bits)
Cazure95
@face_off & TRRazor, I'm a bit of an in-experienced user in Octane, where exactly can I find the environment tab?
I'm using the C4D plugin, so I don't know if the instruction can be applyed the same.
TRRazor
It all really depends on the lighting in your scene.
Try to have one direct light source, either in your HDRi map, or use the Daylight environment (it's easier to get great results with this).
I attached a screenshot, showing you some starting point settings. If your scene is not visible after applying these, try playing with the medium scale and medium density nodes.
Cazure95
TRRazor wrote:It all really depends on the lighting in your scene.
Thanks man! I'll dive into this as soon as possible.
Return to “DAZ Studio”
