get caustics
terold
Hi everyone,
I am kinda new in here, but I hope you can help me.
I am running on the 3D Studio Max Plugin, and I am trying to get some proper caustics. I read to get caustics we have to use PMC, one light emitter, but still, i can't get any caustics in my render and i don't see why. Please enlight me.
Here is my test scene with just a shadow from the glass. i read somewhere to uncheck "fake shadow" right?
and here are my settings for kernel and material:
Some thoughts?
Firstly you need to activate the "fake shadow" option, than you need a tiny light source to reduce the blurriness.
Then, in the kernel settings, reduce the Parallelism to 1 and rise back the GI Clamp (this parameter cuts the coustics).
I hope to have not forget anything :roll:
ciao beppe
terold
Thanks for the reply. This is what I get with your setting:
terold
For the record, my system unit scale is: 1unit fo 1 millimeters
I know there are some trouble if you use the wrong unit scale, so I also try 1 unit for 1 meters, and it doesn't look better.
mmm, the shadows seem still way too soft, there is surely an issue with the scale :roll:
How big is your light source?
Please, try this, disable the emitter and use the physical sky, you should see a big difference in terms of shadow and coustic sharpness.
ciao beppe
terold
It looks to works with a day light:
But I am not a huge fan of the octane day light, I had a better control and a better look with the octane light. You guys always use daylight for caustics render?
nuno1980
Welcome to terold! :)
You're interested caustics. And I also! :D
What's your videocard?
If you're interested REAL-LIFE, then you should:
--> glass material
- disable "fake_shadows"
- enable dispersion 0.005* -> therefore, ior original 1.500 -> change to 1.483** ior dispersed
--> PMC settings
- set maxdepth 16 (both diffuse and specular)
- parallelism 1 for appear caustics earlier
- keep to disable "caustic blur"
- change to max GI clamp
- if your great area of light emission then change to ~8,000 samples per pixel (spp) or if it's sun on earth then set 100,000~150,000-spp at 1002x602 (resolution screen)
* -> formula of dispersion conversion: (n_d - 1)/v_d*((0.48613^2*0.65627^2)/(0.65627^2 - 0.48613^2)) = dispersion coefficient
n_d - it's ior
v_d - it's abbe number
** -> formula: ior_orig - 10/3*coef_disper = ior_disper
IMPORTANT: Any specular material ALWAYS has dispersion at real-life. ;)
If you've any doubt then you can contact me. ;)
PT vs PHT kernels - spp nrs
Caustics at PT
NOTE: Sorry, my bad English for mute ;)
i7-12700KF
32GB DDR4@3600
GF RTX 4090 <3 :mrgreen:
NEW ACER Predator XB273U F5 27" :D
terold wrote:It looks to works with a day light:
as I told you, there is a problem with your scale settings, the physical sun is like an infinite point light so you should have coustics even if the scale is wrong. In theory, with a correct scale, you should obtain almost the same effect with an emitter of 1 or 2 cm ;)
ciao beppe
terold
Thanks nuno, i go to try your settings right away!
and about my videocard, it is a geforce GTX760.
terold
It works really fine. Acutally, I had to use IES light for a better render and caustics works.
