Hi guys, many thanks for your supports. I'm very glad to work on this plugin.
Btw, i wish to make this version as stable. So any feedbacks for issues will be great.
Best regards,
Ahmet
Version 2.24.2-TEST6 - Test only
- fuchsundvogel
could it be somehow possible to give the instances produced by the scatterobject different colors.?
in 3dsmax this is possible with forestpro for example.
http://www.itoosoft.com/tutorials/tutor ... nbarn5.php
It generates Octane scatter node at the end. So you can use random color texture.fuchsundvogel wrote:could it be somehow possible to give the instances produced by the scatterobject different colors.?
- fuchsundvogel
aoktar wrote:It generates Octane scatter node at the end. So you can use random color texture.fuchsundvogel wrote:could it be somehow possible to give the instances produced by the scatterobject different colors.?
it works! cool
thanks
- fuchsundvogel
R17.032 / Win7
when i copy a object with mixmaterial into a new scene. i get a new mixmaterial with no submaterials applied on the object. the old and working mixmaterial is also in the new scene but not applied to the object.
- mixmaterial_bug.zip
- (102.42 KiB) Downloaded 171 times
fuchsundvogel wrote:R17.032 / Win7
Same topic, other issue i forgot to post here - When i copy an object with mixmaterial into a new scene the object and mixmaterial transferred fine but the mix amount slot arriving empty (Screenshots from source and target scene attached )
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0
https://yambo.me
https://yambo.me
Can someone try this version for problem? I hope that i found a solution.fuchsundvogel wrote:R17.032 / Win7
https://render.otoy.com/customerdownloa ... .1-win.zip
copy/past mix mat seems to work well here,on r17 win 7x64 with 5.1.
also solo fonction compatibility is a very nice add
pxlntwrk.net
pxlntwrk.net
Not working for me on this version Ahmet (R17) - Now nodes of the mix material amount transferred to the other scene but they not connected. (screenshots attached)
BTW - View - frame all / frame selected not working in node editor. it zooming out to the maximum.
https://yambo.me
https://yambo.me
- fuchsundvogel
when i create a mix material it will not render the preview until i click in the materialmanageraoktar wrote:
- mixmaterial.mp4
- (386.73 KiB) Downloaded 3745 times
