Version 2.24.2-TEST6 - Test only
Hi guys, many thanks for your supports. I'm very glad to work on this plugin.
Btw, i wish to make this version as stable. So any feedbacks for issues will be great.
Best regards,
Ahmet
fuchsundvogel
could it be somehow possible to give the instances produced by the scatterobject different colors.?
in 3dsmax this is possible with forestpro for example.
http://www.itoosoft.com/tutorials/tutor ... nbarn5.php
fuchsundvogel wrote:could it be somehow possible to give the instances produced by the scatterobject different colors.?
It generates Octane scatter node at the end. So you can use random color texture.
fuchsundvogel
it works! cool :)
thanks
fuchsundvogel
R17.032 / Win7
when i copy a object with mixmaterial into a new scene. i get a new mixmaterial with no submaterials applied on the object. the old and working mixmaterial is also in the new scene but not applied to the object.
mixmaterial_bug.zip
(102.42 KiB) Downloaded 201 times
Yambo
fuchsundvogel wrote:R17.032 / Win7
Same topic, other issue i forgot to post here - When i copy an object with mixmaterial into a new scene the object and mixmaterial transferred fine but the mix amount slot arriving empty (Screenshots from source and target scene attached )
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
Can someone try this version for problem? I hope that i found a solution.
https://render.otoy.com/customerdownloa ... .1-win.zip
pxlntwrk
copy/past mix mat seems to work well here,on r17 win 7x64 with 5.1.
also solo fonction compatibility is a very nice add :-)
pxlntwrk.net
Yambo
Not working for me on this version Ahmet (R17) - Now nodes of the mix material amount transferred to the other scene but they not connected. (screenshots attached)
BTW - View - frame all / frame selected not working in node editor. it zooming out to the maximum.
https://yambo.me
fuchsundvogel
when i create a mix material it will not render the preview until i click in the materialmanager
mixmaterial.mp4
(386.73 KiB) Downloaded 3779 times
Return to “Releases”
