animation exposure doesn't match
Moderator: BK
Elele
How come the animation exposure doesn't match the normal rendering exposure? The animation is way too bright, compare to just rendering an image. I don't know if it is due to the exposure, could be something else causing it to be too bright.
I'm still using the 2.2 (last beta) version. Anyone had this problem?
linvanchene
Elele wrote:How come the animation exposure doesn't match the normal rendering exposure? The animation is way too bright, compare to just rendering an image. I don't know if it is due to the exposure, could be something else causing it to be too bright.
I'm still using the 2.2 version. Anyone had this problem?
In the animation tab there are settings to
- choose the environment
- choose the render settings
In many cases I noticed that not the last environment or render setting that was edited is choosen to render the animation.
Example: I used the HDR environment for image rendering. But when I start the animation by default the daylight environment is chosen.
It might very well be that you adjusted the exposure in a different render setting then the one that was selected in the animation tab. This happens especially when scenes are merged and many different environments or render settings are added to the list.
Side note: In the preferences tab is an option that prevents additional environments, render settings or unused materials are added when loading or merging scenes.
You may have to manually select the proper environment or render setting in the animations tab from the pull down menu.
It can help to use the "Rename" button to give the environment or render setting a more distinct name to quickly see if the proper one is selected in the pull down menu in the animation tab.
Win 10 Pro 64bit | Rendering: 2 x ASUS GeForce RTX 2080 Ti TURBO | Asus RTX NVLink Bridge 4-Slot | Intel Core i7 5820K | ASUS X99-E WS| 64 GB RAM
FAQ: OctaneRender for DAZ Studio - FAQ link collection
Elele
I tried saving render settings already. I'll see if maybe the environmentsetting has something to do with it.
Elele
Nope still doesn't work :(
Tried saving both the rendersettings and envirnoment with new names and switching, but it has no effect.
Elele
Is there a way to export the animation to the sandalone?
It is nothing fancy, just a turntable animation with just one object animated/rotating.
You can export an animation to Octane Standalone in the new TEST release at viewtopic.php?f=44&t=51410.
If this is still happening on the latest version, can you post some screenshots of the animation and your settings pls. A sample scene using a cube prop would be helpful too. My best guess is that animations are saving with tonemapping turned off. What filetype are you saving too? png or exr? If exr - there are Linear/Untonemapped options, which will save in a different color space to what you see in the Viewport.
Elele
I tried with the new version in ds4.9 but still get the same result. I tried saving in all the available image formats, but still get the same result.
Here are the settings and i added a render of the still render and one of the animation render.
Elele
So I downloaded the new version, how can i export the scene?
linvanchene
Elele wrote:So I downloaded the new version, how can i export the scene?
Check the
OcDS: System Tab - Export scene
For now a link to an old post that shows a screen shot with the export settings and some other information:
viewtopic.php?f=44&t=44402#p219089
If you are not yet familiar with OctaneRender standalone the online manual has been updated with a lot of information:
https://docs.otoy.com/#51Interface%20Overview
There are also links to video tutorials on the landing page:
https://docs.otoy.com/#rOctaneRender%20Universe
Can you send me the scene pls?
Return to “DAZ Studio”
