[Q] Control texture image sequence frame with XPRESSO?
QubaHQ
I am trying to create a simple XPRESSO to assist me with animating the texture used in Octane Shader, pulling frames based on my input rather than just time... but can't get the proper nodes to show up in XPRESSO editor.
I managed to ghetto-rig it using driver/driven relationship - it works during output render, but lags in preview.
Any ideas?
Yambo
you can simply put animated texture insides octane image texture and it will work.
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
have you tried to change the expression's priority?
Maybe you have some other calculation that is blocking the flow :roll:
ciao beppe
QubaHQ
bepeg4d wrote:Hi,
ciao beppe
Yes, tried that, unfortunately did not help, since only a part of it is an XPRESSO node I can prioritize. As far as I know there's no way to increase the priority of driver/driven relationship... or is there?
QubaHQ
Yambo wrote:you can simply put animated texture insides octane image texture and it will work.
I already have animated texture there - what I want to do is to control playback using XPRESSO.
QubaHQ
Here's the idea:
I want to be able to control the Movie Start Frame using XPRESSO, but when I add my material to XPRESSO editor, under diffuse only Color, Float and Mix show up as "hookable" attributes.
