Turbo smooth render iteration not working with octane
jim99
My problem is mesh/turbo smooth modifiers, does not update when octane viewport renders .
For example I have set my turbo smooth modifiers render iteration 2, when octane renders it doesn't apply the iteration 2 to the object
We need this feature, since our production files are huge, if we turn on turbo smooth modifiers on in view port it will be impossible to move
around in the viewport also crashes max in some cases.
I am wondering if there are anyway to work around it ?
Do I need to export the animation into standalone version and add smooth to it ? Can someone at 3dsmax plugin department help me with this ?
Jimmy
gueoct
jim99 wrote:...... if we turn on turbo smooth modifiers on in view port it will be impossible to move around in the viewport .....
As soon as you hit "render" you can´t move around in the viewport anyway, right?
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
HHbomb
Select your object and in octane properties check "Movable proxy" and run octane viewport
gueoct
HHbomb wrote:Select your object and in octane properties check "Movable proxy" and run octane viewport
You are right. Of course that works. But as far i understood, jim99`s question was about iterations at render time. (?)
jim99
No my question is about Turbo smooth modifier / render iteration function - It should subdivide geometry only at render times which works with vray and all other renders
but not Octane, this is like a basic function in 3dsmax for fast previews when you are working in a complex scene.
gueoct
Yeah, that´s a pity!
Dom74
be sure to turn on "use render objects setting" in kernel panel.
use render obj setting
Win7 x64 - 3DSMAX 2019 - 32GB RAM - 1080 TI
gueoct
Wow, Thanks a lot for that hint!
I must say i t again: Octane Manual is a shame!!!!!!!
i haven´t seen any other software that is so poorly documented........
jim99
Thank You Dom, we spend 1 week search forum for this function, it could be simply included in the manual ....
But it doesn't seems be to update on the fly. Once you set it, if you want to change render iteration again, you will have to on and off tubosmooth to update it.... It will be great to fix that issue..
Return to “Autodesk 3Ds Max”
