OctaneRender® for 3ds max® v2.23.2 - 2.6 [OBSOLETE]
Elvissuperstar007
HDR BUG
if you change the placement of the texture environment through 6-7 clicks environment ceases to change
we must re restart the viewport
oguzbir
Hi Jim,
Not only these.
Dragging and copying any material or texture in material editor, results in stopping octane viewport update..
I would really like to know when would you release fixed version. Or would it take time to correct it?
Thanks.
My Portfolio
oguzbir
Jimstar hi,
I honestly and truly hate to ask this again but do you have plans to fix the bug I mentioned previous post?
( drag and drop copying any material halts viewport update )
I've lost the effectiveness of keeping the octane viewport on while working since max plugin ver. 2.0
Or we'll have to wait for v3?
I guess you may not say when.
My Portfolio
Goldisart
don't support the sequence of images
Oh God when that day comes when octane in functionality to perform all the available functions 3dmax
when will I stop spitting from minor mischief in this perfect render :?
Goldisart
where did the triangles please tell me ?
I found a way to deal with error (Smooth Chamfers only + to Smooth Adjustment)
test.rar
(25.43 KiB) Downloaded 327 times
profbetis
Norman, just go back and download the previous version. No one is making you use this version.
GTX 1080Ti 11GB (3x), Water-cooled
Intel i7-5820K 6-core @ 3.3GHz
Windows 10 Pro 64-bit, 32GB RAM
mikinik
Goldisart, what are you mean? what kind of nonsense? octane has nothing to do with it.
on the top view of lighting is flat, so triangles are not visible.
r9 3900x/64Gb/2070s/2070/win10x64/3dsmax2021
ramone163
Max 2014 crash when trying add some render pass to RenderElements window.
GPU: 2x4090; 3ds max;
Behance portfolio; Handmadefont.com;
Goldisart
1. does not work correctly render elements - black frames . 2. Does not work correctly sequence the render (black frames) - skips between frames empty frames render
the standalone version (OK!) - it works during the conversion output is only to convert the animation in the standalone version
2015-08-31 16-21-16 XnView - [Обозреватель - F  ... Командор 2015 -50 на двери купе render final ].png
shonsu
Locked
Return to “Releases”
