1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
- Fixed the live-preview lag.
Installation:
- Just run the installer to see its command line keys.
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &DOWNLOAD
Blender Octane Edition - v9.3 Linux (99.8MB autoinstaller file)
For network slave and daemon please download standalone installer here:
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
 I can't get a HDRI to work anymore.   It's much harder to set it up now,  as you have to create a texture to put in the texture slot for the environment.  But even then it doesn't work and the image is not displayed.
