OctaneRender™ for Blender 2.23.2 - 9.3 Linux [OBSOLETE]
JimStar
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Fixed the live-preview lag.
Installation:
- Just run the installer to see its command line keys.;)
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v9.3 Linux (99.8MB autoinstaller file)
For network slave and daemon please download standalone installer here:
http://render.otoy.com/forum/viewtopic.php?f=24&t=46125
mib2berlin
Hi, thanks for the update, first tests work fine so far.
Cheers, mib
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
kaiwas
Thanks, nice work!
grimm
Thanks Jimstar, working well. I am having an issue with OpenSubDiv. When I enable it on an object (in this case just the simple cube) it makes the render start really slow. It will sit there with "Render-target evaluation on server..." displayed for 30 seconds or longer before the render will start. It depends on which level I set the subdiv to, by level 4 (on the simple cube) it's too slow to use. But when the evaluation is finished it's fast again. Is this how OpenSubDiv works? It doesn't seem right to be this slow for such a small number of polygons?
Also when you first turn on OpenSubDiv the viewport does not update unless you change the settings or move the view.
grimm
Hmm, more issues. :( I can't get a HDRI to work anymore. It's much harder to set it up now, as you have to create a texture to put in the texture slot for the environment. But even then it doesn't work and the image is not displayed.
Does anyone else have these problems?
mib2berlin
Hi grimm, I have no problems with HDR lightning and iirc setup is same since first implementation.
I have problems to get displacement to work.
Cheers, mib
EDIT: Cant upload files!
For grimm: http://www.pasteall.org/blend/37366
For Jim: http://www.pasteall.org/blend/37367
grimm
Thanks Mib your blend file helped, but I still don't remember having to setup a texture node to get it to work. It's ironic that I don't have any problems with displacement, I can add a blend for you if that would help?
mib2berlin
Thanks, may you can check the second .blend.
Sometimes I get it to work but not every time with exact same settings, no idea why.
Cheers, mib
grimm
Hey Mib,
You needed to unwrap your ground plain before you can use an image to displace it. :)
mib2berlin
Argh, every time these simple solutions, tsk tsk.
Many thanks. :)
Cheers, mib
Locked
Return to “Blender”
