that's why Octane ies lights have never worked
Sub forum for bug reports
C. RAM Capacity (i.e. 6 GB)
gabrielefx
This is a simple test comparing Octane Vs Thea ies lighting.
This is a closed room with 64 photometric lights.
The same materials were created in Thea.
I used PT 16 bounces for both scenes and 5 minutes of rendering.
Octane ies lighting, distribution, sampling, directional features have to be reprogrammed from scratch.
Make your conclusions.
regards
oguzbir
Gabriele would you mind sharing the same scene I'd like to give it a go with other renderers
best
My Portfolio
sadece
this is huge diffirance :?
http://www.sadece.com.tr
i7 990x // 12GB Ram // 2x Titan X + Titan + 780 // Octane for C4D // Win7 x64
abstrax
gabrielefx wrote:This is a simple test comparing Octane Vs Thea ies lighting.
regards
That's a bold statement. What's the shape of the emitters? Unfortunately you made them transparent so we can't see them.
Strange, so what's this?
inlifethrill
gabrielefx what did you use to orient the IES lights? I hope you didnt simply rotate the area lights to point downward..
Dobs
gabrielefx
I used path tracing, not direct lighting.
I will post the Max scene.
gabrielefx
This is the scene, it's quite simple.
You will find a layer with 64 flat 2d emitters, you can turn it on. This layer works better than standard ies, less noise, in fact I always use shapes for ies lighting.
I think that Karba did some mistakes creating ies lights in Max or there are issues in the kernel.
caustics_test_Octane_ies.zip
(40.7 KiB) Downloaded 239 times
gabrielefx wrote:I used path tracing, not direct lighting.
yes, this is PT.
Return to “Bug Reports”
