This is a simple test comparing Octane Vs Thea ies lighting.
This is a closed room with 64 photometric lights.
The same materials were created in Thea.
I used PT 16 bounces for both scenes and 5 minutes of rendering.
Octane ies lighting, distribution, sampling, directional features have to be reprogrammed from scratch.
Make your conclusions.
regards
that's why Octane ies lights have never worked
C. RAM Capacity (i.e. 6 GB)
- gabrielefx
Gabriele would you mind sharing the same scene I'd like to give it a go with other renderers
best
best
My Portfolio
this is huge diffirance
http://www.sadece.com.tr
i7 990x // 12GB Ram // 2x Titan X + Titan + 780 // Octane for C4D // Win7 x64
That's a bold statement. What's the shape of the emitters? Unfortunately you made them transparent so we can't see them.gabrielefx wrote:This is a simple test comparing Octane Vs Thea ies lighting.
regards
- inlifethrill
- Contact:
gabrielefx what did you use to orient the IES lights? I hope you didnt simply rotate the area lights to point downward..
Dobs
Dobs
- gabrielefx
I used path tracing, not direct lighting.
I will post the Max scene.
- gabrielefx
This is the scene, it's quite simple.
You will find a layer with 64 flat 2d emitters, you can turn it on. This layer works better than standard ies, less noise, in fact I always use shapes for ies lighting.
I think that Karba did some mistakes creating ies lights in Max or there are issues in the kernel.
- caustics_test_Octane_ies.zip
- (40.7 KiB) Downloaded 260 times
yes, this is PT.gabrielefx wrote:I used path tracing, not direct lighting.
