Quick translucency tests
radiance
the top part of the tree, there's a branch that suddenly swaps places ?! :)
Radiance
n1k
True:) heheh. That's why I said it turned out a bit funky:) I finaly got a grip on max2octane plugin so will be posting some nicer trees in the wind soon.
[email protected], 8gb RAM, Gainward GF 460 GTX 2048mb,Win7 64bit.
http://continuum3d.blogspot.com/
brobo
How did you bring the animation into Octane? Sorry, if someone asked this already.
BROBO.TV - Core i7 X980 @3.33Ghz | 32gb | Windows 7 Professional 64-bit | EVGA Geforce GTX Titan
Cinema 4d R14 + Octane 1.10
ltchest
[quote= you just need to make a diffuse material node, connect it to your material input on your object node, and connect a texture or rgb spectrum to the transmission input, then you can play with the sliders of both reflection and transmission to get the desired effect.
also, you must enable pathtracing to see the effect as directlighting does'nt show it.
Radiance[/quote]
where can we read more about this kind of workflow ? it looks interesting....but very very different to what i am used to. i understand the whole 'node' workflow but cant find anything in the manual. i generally find the terminology confusing - would be great to see a summary somewhere....
Win7 64bit. i7 3930K 4.2Ghz.32GbRam. GTX670(4Gb)+2xGTX580(3Gb) | 3xGTX780(3Gb). 337.88. 1200W. (+ 5 x i7 2600 nodes).
lechu
Just another shot. 4.30 min on GTX 480 ;)
n1k
Nice:) It's faster when you use geometry leaves without opacity maps ;) When instances get supported it will be real joy rendering outdoor scenes with a lot of vegetation.
Cheers,
n1k
lechu
Another test :)
Chris
lechu wrote:Just another shot. 4.30 min on GTX 480 ;)
I love it man :)
Did you use the same material settings as the first you posted? I see a lot of color variations wich makes it look very real, how did you do that?
Chris.
________________________________________________________
Win 7 64 | 1x GeForce GTX Titan | AMD Phenom II X6 3.20Ghz | 16GB
lechu
Yes, the settings are pretty much thesame. Just changed some trnasmission color, camera values etc.
n1k
Hi guys. I ran quick test mixing diffuse material (with diffuse transmission turned on) and glossy material to get a leaf shader. So here is the result:)
cheers,
n1k
Return to “Works In Progress”
