Text on texture ?
Emil_0lsen
I have a little newbie issue I hope that someone can help me with.
Im trying to put at Png image (With only text and transparrent background) on a texturet object and isolate it for at specific area. I can make a texture with transparant background and mix textures but not put text on a texturet object without affecting the "base" color?
Emil_0lsen
Im in C4D
Yambo
i׳m not sure i got you, upload a scene file please.
4x 980ti EVGA | 5930k | Asus X99 E WS 3.1 | corsair 64GB RAM |SSD 500GB system + SSD 2TB working files + 6TB HDD storage WD |
Phanteks Enthoo Primo | 1600W EVGA T2 BLACK | It's the fastest 4x980ti build: http://goo.gl/hYp8e0 :)
https://yambo.me
smicha
Some time ago I did a scene where I had to move a sticker over a cardboard cylindrical package. Here you go - use mix materials with the alpha image and the rgb image. For details I am uploading orbx - go to oxidizer group and play with transforms.
oxid.orbx
(29.86 MiB) Downloaded 381 times
Emil_0lsen
Basically I want to put on a image (with no background) on another texture, without mixing there values.
smicha
Use the solution I sent. It should work.
Emil_0lsen
Sorry.. Saw youre post after I posted my replied.. Im in Cinema 4d.. But i it gave me a direction :)
for translating in c4d-octane of what smicha correctly suggest, you have to use a b&w version of your texture in the amount channel and modify the "border mode" option in order to disable the tiling of the texture.
Here is a simple scene in c4d and ocs format ;)
Decal.zip
(95.99 KiB) Downloaded 420 times
ciao beppe
Emil_0lsen
THANKS !! Very help full of both of you!!
Emil_0lsen
The only issue is that my png is effected by the color of the rgb spectrum, not by its original color ? im trying to put a image insteed for the rgb spectrum, but i dosnt semees to work :) ..
